decdd19 Posted December 28, 2014 Posted December 28, 2014 Where to even start engine an all is out... Tidy up or move fusebox? Quite good with my wiring but this has me baffled on where to even start ha Quote
5e colin Posted December 28, 2014 Posted December 28, 2014 move fusebox in glovebox area ?? the loom section for injectors and knock etc etc run it under the feul rail that will get rid of loads of wires i think the rest is just a matter of how hard you can pull tuck smaller wires out of view ????? Quote
decdd19 Posted December 28, 2014 Author Posted December 28, 2014 Basically strip off all the conduit an black tape an start reorganising? Quote
turbo Grant Posted December 28, 2014 Posted December 28, 2014 Lable every thing. Cut all out and re run the wires out of sight. It's a lot of work with lots of soldering but well worth the effort. Quote
_shaun_ Posted December 28, 2014 Posted December 28, 2014 It's very time consuming. Just make sure your soldering skills are upto par before you start. Ive done small things like alarms and different wires and you can lose half a day just trying todo 2 wires. Be a lot easier with your engine out and ina proper garage tho Quote
decdd19 Posted December 28, 2014 Author Posted December 28, 2014 Lable every thing. Cut all out and re run the wires out of sight. It's a lot of work with lots of soldering but well worth the effort. cut the connectors off? obviously not close to the connector then label that wire an go from there is what ya mean? Quote
TurboTobz Posted December 28, 2014 Posted December 28, 2014 Label either side of cut pull through to cabin cut one by one shorten and join them. Quote
decdd19 Posted December 28, 2014 Author Posted December 28, 2014 still run them through both bulk head holes? Quote
_shaun_ Posted December 28, 2014 Posted December 28, 2014 I'd run them thought the passanger side wing Quote
mikey4410 Posted December 28, 2014 Posted December 28, 2014 relocating the fusebox takes around 20 hours and is a horrible job I wud never ever do again.fuse box is in the glove box.and some wiring went through the wing.pics are in my build thread of engine bay without fuse box etc Quote
turbo Grant Posted December 28, 2014 Posted December 28, 2014 You don't need to cut every thing off. Some wires will just need rerouting. Run lights and horn and fan wiring in the wings. Engine electrics I just used the hole in the middle of the bulk head at the bottom Quote
