LukeColby Posted January 2, 2015 Posted January 2, 2015 Got in my glanza the other day and realised it was steamed up so checked the carpets and found that the passengers floor was very wet.Checked under carpet and no sines of a leak any ideas? Quote
Chris Green Posted January 2, 2015 Posted January 2, 2015 Heater matrix possibly, have you had the heater going? Quote
_shaun_ Posted January 2, 2015 Posted January 2, 2015 I'd like to hope its from excited female passangers! But its more likely a leak from the skuttle panel or door. The rare occasion it can be the heater matrix aswell Quote
LukeColby Posted January 2, 2015 Author Posted January 2, 2015 I'd like to hope its from excited female passangers! But its more likely a leak from the skuttle panel or door. The rare occasion it can be the heater matrix aswellHaha that was amazing but no heater matrix is dry, so possible skuttle panel or door is there a point it normally leaks? Quote
MR-2 Posted August 4, 2016 Posted August 4, 2016 I have LHD model, and radio antenna is also left side, don't know RHD model is it same side. But founded leaking point, antenna tube has water exit pipe and it was pointing/bended to inside, should go inside a-pilar and sill... Quote
fiddlersport Posted August 4, 2016 Posted August 4, 2016 You losing coolant ?Heater matrixRubber gromit on door and bulkheadYou running ac ?Check the pipe on bulkhead out of condensor if its blocked Quote
morgey Posted August 4, 2016 Posted August 4, 2016 Theres also rubber grommets in the floor. Both mine are missing Quote
roachburger Posted August 19, 2016 Posted August 19, 2016 Have you had the windscreen replaced ? Check the drivers side too Quote
