jomista2k7 Posted January 12, 2015 Posted January 12, 2015 As above bought a ct9 that hasn't been used in the last year is there such thing as bleeding a turbo in? Quote
5T4R7ET N/A Posted January 12, 2015 Posted January 12, 2015 When you put the turbo on the car you will need to prime it.Take out the efi fuse and crank engine until you have oil coming out of the turbo oil retun pipe. Normally I would say 20-30 seconds of cranking is enough Quote
Gainzy Posted January 13, 2015 Posted January 13, 2015 Or you can disconnect the king lead and crank it that way Quote
funny onion Posted January 13, 2015 Posted January 13, 2015 Or you can disconnect the king lead and crank it that way If you just disconnect the king lead and then turn it over you'll flood the engine as the injectors will still inject fuel... Quote
daniel_g Posted January 13, 2015 Posted January 13, 2015 Since the turbo is out id inject some oil into it with a syringe, then prime the normal way. Quote
