tommyep82 Posted January 12, 2015 Posted January 12, 2015 Anyone using evo 4 or 6 injectors they are 510cc and 550cc. Thinking of using these on my build as can't afford denzo ones. Just want to know is anyone here using them. I will be mapping tuning developments hybrid td04 @ 1.4 bar boost. Quote
akyakapotter Posted January 12, 2015 Posted January 12, 2015 http://www.ukstarletowners.com/topic/83964-td-430cc-injectors-denso/#entry1074070 why not get these. Quote
tommyep82 Posted January 12, 2015 Author Posted January 12, 2015 Was told I needed bigger ones again 460s + to be on the safe side. And evo injectors are alot cheaper cost me over 300e for denso 2nd hand and 70e for evo ones and u just need the plugs so there is a big price difference Quote
Stu Posted January 13, 2015 Posted January 13, 2015 Yep have used 560cc evo injectors and ballast resistors on quite a few builds ive done Quote
5e colin Posted January 13, 2015 Posted January 13, 2015 i have a link for strait fit 1s for 200euros to 250euros they go to 800cc Quote
tommyep82 Posted January 16, 2015 Author Posted January 16, 2015 I Don't want to go to big either could cause bad idle. I can pick evo ones up with plugs resister every thing needed for 60 euros so I just want to know they are still good enough. 200 + is pricey enough just for injectors but want to do it right too Quote
Phil Posted January 16, 2015 Posted January 16, 2015 I Don't want to go to big either could cause bad idle. I can pick evo ones up with plugs resister every thing needed for 60 euros so I just want to know they are still good enough. 200 + is pricey enough just for injectors but want to do it right too modern densos will idle better than stock (even the big cc ones). make me an offer on those 540s i have and you will have yourself direct fit/big cc/with improved spray pattern over stock. (and quickly before i post a forsale ad lol) Phil Quote
Stu Posted January 16, 2015 Posted January 16, 2015 As above, idle ahouldnt be an issue. My 4agte has 800s which are not thar huge but idle is perfect Quote
