Polson2k9 Posted January 18, 2015 Posted January 18, 2015 Hi, my glanza makes a loud ticking noise when idling from cold. It goes away once warmed up but continues to make it when i rev it up lightly. Any ideas what this could be? Quote
russ78 Posted January 19, 2015 Posted January 19, 2015 cracked exhaust manifold is very possible Quote
Vturbo Posted January 19, 2015 Posted January 19, 2015 As above I had the same issue and the head had a crack in it around the manifold stud Quote
Polson2k9 Posted January 19, 2015 Author Posted January 19, 2015 Sounds like its coming from the speedo though. Cant really hear it from the outside, also drives and starts up fine. Quote
glanzadude Posted January 19, 2015 Posted January 19, 2015 cracked exhaust manifold is very possibleGood info there my car was the same way but couldn't find the problem as the heat sheld was covering it Quote
Polson2k9 Posted January 19, 2015 Author Posted January 19, 2015 Different forums just saying its the injectors and not to worry. The noise is not coming from the manifold? Quote
Duduglanza Posted January 21, 2015 Posted January 21, 2015 if you are running bigger injectors or aftermarket pistons.. then its normall.. Quote
Polson2k9 Posted January 21, 2015 Author Posted January 21, 2015 No idea what injectors are in it but its definitly not the manifold Quote
gazza g Posted January 21, 2015 Posted January 21, 2015 Standard noise, all both starlets o owned does it and so does my mates Manifold leak usually a clicking type of noise when you Rev Quote
Polson2k9 Posted January 22, 2015 Author Posted January 22, 2015 Ok so nothing to worry about then? Quote
jimmymac101 Posted January 22, 2015 Posted January 22, 2015 Starlet injectors are known for making loud ticking noise, so dont stress to much but if your not 100% take a vid and try upload it and that might get better answers James Quote
toyotag2014 Posted January 22, 2015 Posted January 22, 2015 ive got the same thing going on ever since the winter came its ticking loud and it seems to be getting louder and loudr or is this just me thinking it is geting louder ? Quote
Matt1878 Posted January 22, 2015 Posted January 22, 2015 Starlet injectors sound very ticky. Even more do if they are bigger than standard.Get yourself under the bonnet and have a real good listen about to try and eliminate manifold cracks etc Quote
toyotag2014 Posted January 23, 2015 Posted January 23, 2015 ill check the mani dude and the injectors are standard Quote
Polson2k9 Posted January 23, 2015 Author Posted January 23, 2015 Mines not coming from the mani, sounds like the top of the engine bay just accross from the idle control valve. Quote
