oil filter relocation kit
Just after a few peoples thoughts and/or directions, I am currently looking for a oil filter relocation kit because my turbo is far too tight to the oil filter, to change the filter im having to disconnect the oil feed line to rotate the turbo to unscrew the oil filter.
Im using a oil filter sandwich plate at the moment for my prosport gauges but i just need filter housing and the housing that sits on the block but im having trouble to find something. i have done alot of searching about but not found a great deal.
Any help would be great thank you.
Mike
Edited by Gilly
  • 5 months later...
Ya I've seen them but I need 1 where the pipe fitting points down the way instead of out the way on the bit that goes on to the oil filter housing so as it gives me room to get an air filter on my turbo,?
