wax stat and icv removal, whats all needed to be removed?
ever since i rebuilt the 5e and had it in its had a very high idle.
after some research today i seen about how to check if the wax stat is stuck, checked and adjusted idle..... HEY PRESTO!!!!
now, how do i go about junking and blocking up all the pipe work?
i read about the 2part chemical metal in the throttle body hole, but what about the pipe work?
any pics to go along with a description would be appreciated
Thanks
  On 2/16/2015 at 9:53 AM, 5e colin said:
if wanted you can leave al the pipe work and fill up the hole feeding the wax valve and job done
if removing the iacv then tap a thread in there for a bolt :)
What does it run like without the icv colin
