Well lads the rubber seal around the timing cover came off and got caught around the oil pump so it caused the timing on my 4efe to jump so would I be right in saying if I lined up the bottom timing mark and line up the top timing mark put on a new belt it should be okay ? The belt didn't come off and the oil pump doesn't seem to be damaged
As the pistons in the 4efe are domed unlike the 4efte ones you will fined they are a interference engine. I know I have built plenty of these engines to have seen this before! It was only last week I was showing aaddzz123 (Adam) a 4efe piston I have in the shop that has strike marks on it from the valves lol you may be lucky but chances are it will have hit!
If the timing is out, is it just a case of rotating the camshaft sprocket (4E mark to hole) and Crank to mark on oil pump?
yes
