Ollieh17 Posted March 4, 2015 Posted March 4, 2015 Ive bought a wepr sideexit and the lambda hole has been bunged and welded up. I have a aem wideband welded further down into the exhaust. Instead of getting another messy bung welded in can the 0-5v function on the aem be used on the emanage? I am due to get it mapped in the next couple of months Quote
Flaminsam Posted March 4, 2015 Posted March 4, 2015 (edited) The emAnage blue doesn't support a 0-5v lambda sensor reading if I remember right. The standard ecu doesn't either. Standard lambda sensors operate at 0-1v so don't plug the wideband into the standard wiring either. You can get a convertor from eBay that changes the signal (0-5v) to 0-1v if I remember right. Edited March 4, 2015 by Flaminsam Quote
Ollieh17 Posted March 4, 2015 Author Posted March 4, 2015 Had a quick look into a converter and cant find much info Quote
Duduglanza Posted March 5, 2015 Posted March 5, 2015 Aem sensor can be used as narrowband and you can use it with standard wiring. there are 4 settings.. i think p4 of the setting for narrowband Quote
JayJ Posted March 6, 2015 Posted March 6, 2015 Aem sensor can be used as narrowband and you can use it with standard wiring. there are 4 settings.. i think p4 of the setting for narrowband As above, AEM wb can convert the signal to 0-1v by itself Quote
Ollieh17 Posted March 6, 2015 Author Posted March 6, 2015 Good stuff, thatcan replace the lambda then Quote
