RustyEp91 Posted March 8, 2015 Share Posted March 8, 2015 Hi guys just fitted my front Tein coilovers yesterdayThey are secondhand sold as no knocks leaks etcIve adjusted them to 65mm drop and been advised they need to settle in as they are rather highFIRST ISSUE: Upon driving steering is very light and full lock makes a weird noise hard to explainSECOND: when decelerating (no breaking) i hear a squeaking noise from them anyone have a clue why? Are the shot?Any advice would be very apreciated thanks ill post a picture of the height too as its higher than standard :/ Quote Link to post Share on other sites
Rob H@RCH Engineering Posted March 8, 2015 Share Posted March 8, 2015 (edited) Have you had the tracking checked and the geometry? That would cause the steering problems not the shocks on there own Also did you leave everything loose and toghten it up once the weight was on the wheels? The squeaking could be the bushes in the bottom arms. Edited March 8, 2015 by Rob H Quote Link to post Share on other sites
mikey4410 Posted March 8, 2015 Share Posted March 8, 2015 yeah as above .u cant just lower a car and expect all the geometry to be fine.it will be well out. get that sorted and go from there Quote Link to post Share on other sites
RustyEp91 Posted March 8, 2015 Author Share Posted March 8, 2015 Thanks lads i have a couple of days off so ill go get it sorted Feels weird as im also used to only springs which are softer hahaThis is how high its sitting now Quote Link to post Share on other sites
WallaceGlanza Posted March 8, 2015 Share Posted March 8, 2015 You must've adjusted them wrong for it to be sitting that high! As above you need to get the geometry checked when fiddling with any suspension components. Quote Link to post Share on other sites
JDMfreak Posted March 8, 2015 Share Posted March 8, 2015 hows things john are they still sitting up high on the car from the pic i can see the adjuster rings there set way to high they should be around maybe 10 to 15 threads from the bottom these were my rears but ya get the idea how long they should be set imeasured mine from the bottom adjuster ring to the edge of the bottom of coilover where the threads stop i forgot to mention when i was talking to you on facebook all the steering tracking will need to be re-done to compensate for the suspension change Quote Link to post Share on other sites
RustyEp91 Posted March 8, 2015 Author Share Posted March 8, 2015 (edited) Oh god you know i have my wires crossed as my knowledge is very limited i thought making the rings higher up lowered the springs now from your info JDMfreak ive made it higher haha thats embarasing haha Edited March 8, 2015 by RustyEp91 Quote Link to post Share on other sites
JDMfreak Posted March 8, 2015 Share Posted March 8, 2015 Oh god you know i have my wires crossed as my knowledge is very limited i thought making the rings higher up lowered the springs now from your info JDMfreak ive made it higher haha thats embarasing haha haha no harm i posted to ya on facebooke how to set them dead on looking forward to some front slammage pictures Quote Link to post Share on other sites
