Andy32 Posted March 23, 2015 Posted March 23, 2015 Quick question have an adjustable valve on the back of the inlet manifold with a spring loaded adjuster.any ideas whats its for? Quote
Andy32 Posted March 23, 2015 Author Posted March 23, 2015 It looks like an original unit. Do they fit them from factory then?it has 2 pipes coming off it that go to what loops like a map sensor on the bulkhead. Quote
turbo Grant Posted March 24, 2015 Posted March 24, 2015 The map sensor should go straight to inlet with an inline filter. Picture would help Quote
Ollieh17 Posted March 24, 2015 Posted March 24, 2015 Not sure on this and could be miles off. but if it works as a bleed valve could it be a super sketchy crude way of fuel cut? Stopping the map sensor from seeing the true boost Quote
Andy32 Posted March 24, 2015 Author Posted March 24, 2015 Sorry guys been super busy but will try get a pic asap.the unit looks factory fitted so bit random.its just behind the throttle body attached to the back of the inlet manifold. Quote
Andy32 Posted March 29, 2015 Author Posted March 29, 2015 just wondered if anyone had the number of a starlet specialist that i could ring To try and get some info on this valve and where it should be adjusted to.cheers Andrew. Quote
Ryan_EP82 GT Posted March 29, 2015 Posted March 29, 2015 If yr on facebook chris bover ireland is the man to help Andy! Quote
Andy32 Posted March 29, 2015 Author Posted March 29, 2015 Ok thanks mate,will see if i can find him. Quote
WallaceGlanza Posted March 29, 2015 Posted March 29, 2015 If you put a photo up we could tell you if it's meant to be there or not and what it is... if you phone somebody up with the description you're giving I don't think you'll get much help! Quote
daniel_g Posted March 29, 2015 Posted March 29, 2015 If you put a photo up we could tell you if it's meant to be there or not and what it is... if you phone somebody up with the description you're giving I don't think you'll get much help!Exactly haha. Quote
