glentwenty Posted March 25, 2015 Posted March 25, 2015 So I have fitted my 16x7s on the front running 205/55s, I don't have the money to buy new tires or anything the tire is rubbing on the wheel well, when I try turn full lock to the left the left rear side of the tire rubs on well same with the right tire, is there anything I can do to the wheel well just to stop it rubbing? Is it possible to just sand back the but it's rubbing on till it doesn't rub anymore? Or try knock it back a bit? Quote
Johnboy GT Posted March 25, 2015 Posted March 25, 2015 What offset is your wheels? You could fit spacers to help this in the mean time? John Quote
glentwenty Posted March 25, 2015 Author Posted March 25, 2015 They are 38 offset I have 1" spacers on them it's only just rubbing, I'll try upload a photo of where it's rubbing, how do i post a photo on here? Quote
rob_bower Posted March 25, 2015 Posted March 25, 2015 To post a photo you need to use a hosting site like photobucket then copy the img code. Quote
glentwenty Posted March 25, 2015 Author Posted March 25, 2015 I did that rob and it says this forum doesn't allow these photo extensions or something is that because they are jpgs? Quote
glentwenty Posted March 25, 2015 Author Posted March 25, 2015 (edited) This is the wheel on the car, It rubs in this spot here! VVThe left side of the tire so closest side to the camera is the side of the wheel (when i have my 16s on) that rubs on it. the rest of the wheel has fine clearance! Edited March 25, 2015 by glentwenty Quote
Johnboy GT Posted March 25, 2015 Posted March 25, 2015 Have to be a smaller profile tyre then by the sounds of it budJohn Quote
glentwenty Posted March 25, 2015 Author Posted March 25, 2015 Have to be a smaller profile tyre then by the sounds of it budJohnWish i had the money for new tyres Quote
glentwenty Posted March 25, 2015 Author Posted March 25, 2015 Just an update on the rubbing, This is how bad the rub is Its going to take alot more than some sanding! I have tried sanding it back a bit but i think it needs to move back quite a bit. If only i could knock that one area back a little bit then it would all be okay! Quote
MARC MOSS Posted March 25, 2015 Posted March 25, 2015 This is the wheel on the car, It rubs in this spot here! VVThe left side of the tire so closest side to the camera is the side of the wheel (when i have my 16s on) that rubs on it. the rest of the wheel has fine clearance!Fuck man that's just the wrong tyre on the wrong wheel and with an inch spacer as well lol!!! Bid put the standard wheels back on till you can get proper sized tyres. Sorry but they also look ridiculously oversized as well Quote
glentwenty Posted March 25, 2015 Author Posted March 25, 2015 Fuck man that's just the wrong tyre on the wrong wheel and with an inch spacer as well lol!!! Bid put the standard wheels back on till you can get proper sized tyres.Sorry but they also look ridiculously oversized as wellThey are only 16s aha Quote
daniel_g Posted March 25, 2015 Posted March 25, 2015 You'll prob be buying tyres sooner than you want to anyway because the way thata sitting just now the arch will burn through thwm in no time.When i had 16s on my old GT i had 195/45/R16 tyres, even they looked big. Quote
glentwenty Posted March 25, 2015 Author Posted March 25, 2015 You'll prob be buying tyres sooner than you want to anyway because the way thata sitting just now the arch will burn through thwm in no time.When i had 16s on my old GT i had 195/45/R16 tyres, even they looked big.Will 205/50's stop rubbing? Cause i don't have the money to be forking cash out for low profiles :/ Quote
daniel_g Posted March 25, 2015 Posted March 25, 2015 Will 205/50's stop rubbing? Cause i don't have the money to be forking cash out for low profiles :/I doubt it, looks like the overall width and profile of the tyre has to be brought down to a minimum.a 205 50 will have a profile in mm of 102.5 and you currently have 205 55 which have a profile in mm of 112.75, so that would only give you about 10mm less height overall, but the width would still be the same. Quote
glentwenty Posted March 25, 2015 Author Posted March 25, 2015 I doubt it, looks like the overall width and profile of the tyre has to be brought down to a minimum.a 205 50 will have a profile in mm of 102.5 and you currently have 205 55 which have a profile in mm of 112.75, so that would only give you about 10mm less height overall, but the width would still be the same.Looks like ill just have to sell them off haha Quote
