hopalong_neil Posted March 25, 2015 Share Posted March 25, 2015 After a frustrating afternoon where I seemed to have broken more things than fixed, I have finally got one side of my Whiteline anti-lift kit fitted. It seemed like a complete pig to fit and has lead me to my question about the adjustment. According to the instructions and fitting guide you can adjust for maximum castor by sliding the bush towards the outside of the car. The only thing is mine doesn't seem to want to move. It didn't seem to line up very well during fitting but there is certainly no movement in it to the outside of the car, it's hard over to the inside and on rough measurement the wishbone seems exactly where the other side is I haven't changed out, which kind of defeats the object as far as I can see. Has anyone had any experience of this? Is there anything I may have missed? Everything is fitted as it should be with the spacing plate and nicely greased up there just seems to be no movement. Any thoughts on this would be gratefully received, thanks. Quote Link to post Share on other sites
Ollieh17 Posted March 25, 2015 Share Posted March 25, 2015 Did you use some gris to try and pull it over? Gotta give it a big tug Quote Link to post Share on other sites
WallaceGlanza Posted March 25, 2015 Share Posted March 25, 2015 Have you got the bushes offset the right way? You will need to pull the wishbone with a bit of force and hold it as you do the bolts back up (assuming the rest of the wishbone is still connected). Quote Link to post Share on other sites
hopalong_neil Posted March 25, 2015 Author Share Posted March 25, 2015 Bushes are offset with the hole towards the outside of the car. Yeah, gave it a good tug and didn't seem to want to shift Even tried it with all of the other bolts (front wishbone, ball joint and ARB tie) loose and tightened up but no difference. Quote Link to post Share on other sites
Ollieh17 Posted March 25, 2015 Share Posted March 25, 2015 silly question have you left the alk bolts loose while you are trying to tug it over? Quote Link to post Share on other sites
hopalong_neil Posted March 25, 2015 Author Share Posted March 25, 2015 Yeah, I did them up to the point that the spring washers were just about loose. Had a feeling that it might need some welly to move them so didn't want to leave them too loose leaving me with a load of tightening up before they held but not so much that they held everything tight. Quote Link to post Share on other sites
koolza132 Posted April 14, 2015 Share Posted April 14, 2015 I had the same problem on the drivers side and I used a ratchet strap to pull it inline with the holes and done it up with slightly either tightening the strap or loosening it to help get it inline, I also had aload of problems with the nuts which lead having to cut a hole in the floor inside as the weld for the nut gave way, also had to tap and die the threads lol but that's another story Quote Link to post Share on other sites
hopalong_neil Posted April 19, 2015 Author Share Posted April 19, 2015 Finally a bit of success. Changed out the front bushes which were pretty screwed and fitted superpro ones which seemed to free things up enough to get some adjustment.All I gotta do now is free up my seized coilover then it can go for wheel alignment to see how it all looks. Quote Link to post Share on other sites
Andy32 Posted June 3, 2015 Share Posted June 3, 2015 Quick question once you have pulled over arms so that bolts can be tightened do both arms have to be measured to make sure both are the same distance on either side?or do the plates only let them tighten up in one place?also once fitted can you get the wheel alignment reset up as normal?Thanks guys. Quote Link to post Share on other sites
Amjad Posted June 3, 2015 Share Posted June 3, 2015 Andy, A&A tyres in Cardiff charge an extra £20 to adjust castor last time I checked. Quote Link to post Share on other sites
Andy32 Posted June 3, 2015 Share Posted June 3, 2015 cool taking her on at retro at coombe on the 20th so want to get it done by then.do i have to tell them the degrees of adjustment or is it something they will know and sort out?will give them a buzz,thanks bud. Quote Link to post Share on other sites
Amjad Posted June 4, 2015 Share Posted June 4, 2015 No probs. I'm not sure to be honest, I've never had castor set specifically Quote Link to post Share on other sites
