just a quick few bits of info here. if fuel cut is indeed at 4.15 volts which I have read on starlet forums etc then here is some info to help others out.
Edited by mikey4410
I am currently looking into using a totally different map sensor of a different vehicle. voltage and pressure values have to be similar or same obviously.
cant believe nobody else hasnt thought to do it.
People used to use Celica GT4 ones i think.
