My understanding is
2 way locks up fully on acceleration as well as de-acceleration, basically forcing you straight forwards as the inside wheel is unable to travel at a slower speed like it normally would unless you are feathering the throttle into a corner To release the torque on the lsd.
1.5 way does this allowing for some slip
1 way only locks up under acceleration.
Fwd is more suited for 1 or 1.5 way lsd's
This is just how i interpret how they work so if someone can correct it please do :)
Just make a note that's not a full LSD unit like KAAZ, TRD etc, but only some parts you use to convert your existing differential to LSD, hence the "cheap" price.
Morgey explained the differences very well :thumbsup:
My understanding is
^ This.
Good explanation.|!
