Biting point on spec 6 puk
Ok so recently purchased a spec 6 puk from td, got it fitted over the weekend an all seemed well, biting point was half to three quarters up the pedAl, smooth gear changes no crunching, happy chappy, then after driving for about 100 miles noticed that occasionly when pulling off in 1st, the biting point will drop right to the floor, an send me juddering off, and same into second, but then is fine through the rest of the gears, it probably does it like 1 in 5 times of trying too pull off, any ideas what it could be ? I thought maybe air in the system but it hasnt been disconnected so dont know how it would have gotten in, or the slave? But it wasnt doing it before :s or is it just a case of running it in? Thanks
Had the same problem with this clutch in my mates,we replaced the master cylinder and slave cylinder it made no difference it ended up damaging the gearbox i think the clutch plate on them are to thick so we replaced it with a competition clutch with no issues.
Edited by Darzo2010gt
