Ollieh17 Posted April 11, 2015 Posted April 11, 2015 Its been a while somce i took the disks and bearings off my rear beam due to an issue with the bushes. I cant for the life of me rememember the order they go back on.These are the components i have brand new from ICP Quote
WallaceGlanza Posted April 11, 2015 Posted April 11, 2015 Big one on the inside with the seal, small one on the outside - bin the two cases. Quote
Ollieh17 Posted April 11, 2015 Author Posted April 11, 2015 Cheers dude. Seal on first or after the bearing? Quote
5e colin Posted April 11, 2015 Posted April 11, 2015 have you a grease packer ??? otherwise them bearings will need changing again next year or this you cant fir them bearings wrong because the hub wont slide on small 1 is behind tha nut Quote
Ollieh17 Posted April 11, 2015 Author Posted April 11, 2015 Got grease with them, pretty sure the newly supplied bearings are too small Quote
5e colin Posted April 11, 2015 Posted April 11, 2015 (edited) starlet/paseo hub and disk bearings are the same size where do you think these are smaller outer or inner you have to tap out the outer race of the bearings out of the hub there is cut outs to put a punch or the like stick your finger in there you feel it :_p Edited April 11, 2015 by 5e colin Quote
WallaceGlanza Posted April 11, 2015 Posted April 11, 2015 http://www.toyotagtturbo.com/forums/showwiki.php?title=Rear+brake+discs+and+pads+replacement Quote
Ollieh17 Posted April 11, 2015 Author Posted April 11, 2015 The inner bearings supplied by icp were slightly smaller than the oem inner bearings Quote
