starlet Craze Posted April 17, 2015 Share Posted April 17, 2015 Hi there I'm from London and I brought my Glanza a few months ago as a summer project.Was wondering if anyone could help me out...It turns over but doesn't start any help would be greatly appreciatedThanks in advance ! Quote Link to post Share on other sites
Jhandy Posted April 17, 2015 Share Posted April 17, 2015 that could be loads of things bud, your gonna have to narrow it down, like what have you looked into about it not starting Quote Link to post Share on other sites
starlet Craze Posted April 17, 2015 Author Share Posted April 17, 2015 Lol Ok so I've checked if fuel is coming through and it is,I've checked the spark plugs and they are all good,I've put a new battery in it aswell,That's all I've checked so far. Quote Link to post Share on other sites
starlet Craze Posted April 17, 2015 Author Share Posted April 17, 2015 Also the lad I bought it off says it used to cut out on idle. Quote Link to post Share on other sites
starlet Craze Posted April 17, 2015 Author Share Posted April 17, 2015 Can anyone help me out? Quote Link to post Share on other sites
Jhandy Posted April 17, 2015 Share Posted April 17, 2015 Have you checked the timing? A little thing as a coolant sensor can stop it starting bud Check the rotor arm see if it corroded Quote Link to post Share on other sites
starlet Craze Posted April 17, 2015 Author Share Posted April 17, 2015 The coolent temperature sensor is faulty I think is it 2 pin or 1 pin? Quote Link to post Share on other sites
Jhandy Posted April 17, 2015 Share Posted April 17, 2015 2 pin the 1 pin controls the fan Quote Link to post Share on other sites
starlet Craze Posted April 17, 2015 Author Share Posted April 17, 2015 Ok sweet I'll try that Thanks buddy! Quote Link to post Share on other sites
Jhandy Posted April 17, 2015 Share Posted April 17, 2015 If you keep cranking it. It should start eventually. It done it to me once. Took about 15-20secs worth of cranking. Then once it was warm was fine Quote Link to post Share on other sites
starlet Craze Posted April 17, 2015 Author Share Posted April 17, 2015 Ok cool will let you know what happens once I've tried it!Thanks again Quote Link to post Share on other sites
toyotag2014 Posted April 18, 2015 Share Posted April 18, 2015 Crank sensor? Quote Link to post Share on other sites
starlet Craze Posted April 18, 2015 Author Share Posted April 18, 2015 Where is the crank sensor? Quote Link to post Share on other sites
starlet Craze Posted April 20, 2015 Author Share Posted April 20, 2015 Right so I've replaced the coolant sensor and still not starting Anything els I can check?I've checked all the earths and they are good I've replaced the battery Fuel is deffo coming thro And there is deffo spark Thanks in advance. Quote Link to post Share on other sites
Glanza-Ben Posted April 20, 2015 Share Posted April 20, 2015 timing out or engines fubard Quote Link to post Share on other sites
Glanza-Ben Posted April 20, 2015 Share Posted April 20, 2015 Do a compression check Quote Link to post Share on other sites
starlet Craze Posted April 20, 2015 Author Share Posted April 20, 2015 Timing out?It's been running be for tho how can it be the timing?Sorry for all the questions I'm only 17 and as you can tell I'm not mechanic minded lol ☺ Quote Link to post Share on other sites
Glanza-Ben Posted April 21, 2015 Share Posted April 21, 2015 Timing out?It's been running be for tho how can it be the timing?Sorry for all the questions I'm only 17 and as you can tell I'm not mechanic minded lol ☺Running before according to previous owner right? So belt could of jumped a tooth or two Quote Link to post Share on other sites
Calum122 Posted April 22, 2015 Share Posted April 22, 2015 I've just had this. Spark, fuel and oxygen. The car should go mate. That's all that is required. In theory anyway. As Ben says, if the timing is out then you are going to get an issue with oxygen, escaping gases and compression. A compression check will give you an indication. If you're really not mechanically minded, then consider getting a garage to have a look at it. In due time you can learn. But start with small projects and learn the basics and the move on up. We've all got to start somewhere and I found that just building a simple two stroke engine will cover the basics that will put you in good steed to working on something more sophisticated. Quote Link to post Share on other sites
Ollieh17 Posted April 22, 2015 Share Posted April 22, 2015 Charlie on here had a similar issue the other day, was a faulty coolant temp sensor stopping it from starting Quote Link to post Share on other sites
starlet Craze Posted April 22, 2015 Author Share Posted April 22, 2015 Right so manage to get it started .The spark plugs were to blame!Thanks for your help.Will be on road soon☺👌 Quote Link to post Share on other sites
Repa1 Posted July 29, 2015 Share Posted July 29, 2015 Where abouts in London you from mate? Quote Link to post Share on other sites
starlet Craze Posted July 29, 2015 Author Share Posted July 29, 2015 Right do its runs now but smokes a lot it's white and black smoke and the spark plugs have gone very black just put new ones in and only done 0.5 miles just been starting it!What could it be!Ovrrfueling?I'm from east London mate Quote Link to post Share on other sites
morgey Posted July 29, 2015 Share Posted July 29, 2015 White smoke is probably condensation if its not been run in a while. Black is fuel, could be a few things cause that. have you checked for any engine codes By bridging te1 and e1 in the diag port? (Someone correct me if i got the wrong pins) sometimes they have codes but dont throw the c.e.l onIt will cause the engine light to flash in a sequence, if its a constant flash its clear but if its spaced out its throwing a code Quote Link to post Share on other sites
starlet Craze Posted July 29, 2015 Author Share Posted July 29, 2015 Right I'll get it checked but this is the second set of spark plugs I've needed to put it other wise car font start because they are so filthy what's causing this its got a fuel pressure regulator on it as by the way Quote Link to post Share on other sites
