DRiiFTiE Posted April 25, 2015 Posted April 25, 2015 (edited) Ok so my car started to misfire,judder,miss quite a lot.. so i did the following things..- replaced all ignition ( plugs,leads,distributor,coilpack ECT ECT! Then my headgasket went so i have just got the car back.. and its had head skimmed, pressure tested all new gaskets ect!The car now is not getting hot/loosing coolant and not misfiring now so that a BONUS! PROBLEM CURRENTLY - Car is very boggy, as you take off a junction for example in 1st.. the car doesnt want to accelrate so there is a big 2-3seconds delay before the car starts to go.. but then the car will not pull hard and is only just driveable.. ( it does this in all gears & is very boggy ) and there is NOT any throttle response what so ever until atleast 2 seconds.. it never did this before only happended since cars been apart so i check all the VAC pipes and they seem fine.. Ordered a Temp Sensor as it runs a tad better but nothing major when its unplugged..I have noticed the Walbro Fuel Pump has gone very quiet to how it used to WINE very loud. Can anyone help.. if so im litrally willing to send you some £! Thank's alot ! DRiiFTiE! Edited April 25, 2015 by DRiiFTiE Quote
morgey Posted April 25, 2015 Posted April 25, 2015 Have you checked the timing at all With a timing light. Should be done with some ports bridged in the diagnostics port.that or the timing was a tooth out putting the belt on maybe.Worth whipping the top cambelt cover off to make sure its all inline. Same with the cam cover to make sure the inlet cams in check too Quote
DRiiFTiE Posted April 25, 2015 Author Posted April 25, 2015 Have you checked the timing at all With a timing light. Should be done with some ports bridged in the diagnostics port.that or the timing was a tooth out putting the belt on maybe.Worth whipping the top cambelt cover off to make sure its all inline. Same with the cam cover to make sure the inlet cams in check tooThe lad at the garage said he was thinking of checking it with a Timing Light.. think im gunna pop the car back there tomorrow, wasnt doing it at all before just since been put back together.. cheers bud Quote
morgey Posted April 25, 2015 Posted April 25, 2015 If its been apart its quite likely to be one of them. If all the ignition is new and the vac lines are ok the only other obvious thing to check is your boost pipes make sure ones not popped off somewhere. Quote
5e colin Posted April 25, 2015 Posted April 25, 2015 if the ecu temp sensor is diconnected she might do it to so worth a check ( its on thermo housing ) Quote
daniel_g Posted April 25, 2015 Posted April 25, 2015 Seems stupid but make sure all plug leads are on correctly, ie 1 to 1, 2 to 2 etc. on the dizzy Quote
Flaminsam Posted April 27, 2015 Posted April 27, 2015 Sounds to me like timing is out on the ignition. As morgey said, bridge out the two ports in the diagnostic port to set the static timing. 10 degrees before tdc. I also find a paint pen or tipex helps to see the marks on the bottom pulley and the lower timing cover. Quote
