paddy Posted April 25, 2015 Posted April 25, 2015 I've just bought a cusco LSD fitted in a glanza box, I've heard there very noisy and clunky what the best oil for them? Preferably an oil that's going to reduce noise as much as possible. Also do the cusco ones need rebuilding on starlets? Many thanks Quote
AdamB Posted April 25, 2015 Posted April 25, 2015 Yes they need rebuilding, any clutch type LSD does. Motul or Redline oils are pretty good at keeping them relatively quiet. The more important thing than the oil is how you run them in, that really dictates how noisy they are and how long they last before a rebuild. Quote
Gainzy Posted April 25, 2015 Posted April 25, 2015 Had a go of this LSD few weeks ago and BAM I got addicted around the corners straight away, loved it!! Quote
RobSR Posted April 25, 2015 Posted April 25, 2015 Go for some Fuchs Titan Race gear oil from Opie. Thats sorted many clunking diffs that haven't been totally run in properly Quote
_JT_ Posted April 26, 2015 Posted April 26, 2015 I found Millers 75w90 Fully with LSD additive shut mine right up ! Quote
paddy Posted May 8, 2015 Author Posted May 8, 2015 Thanks for the advice, how long before they need to be rebuilt? It will only be road use Quote
AdamB Posted May 8, 2015 Posted May 8, 2015 (edited) Depends how hard its been used, how its been run in etc. They will normally last 1 race season before a rebuild is recommended.The OS Giken LSD's are the best I've seen in terms of durability. Edited May 8, 2015 by AdamB Quote
