kbond Posted April 26, 2015 Posted April 26, 2015 My gt used to sit at around 75-80 on a run and go up a little on a spirited drive but it's been in the garage a few days whilst I done some wiring and yesterday when I went out it didn't go over 65 what could cause it to be so low? And what is the average temp what it should be?Cheers keiran Quote
JayJ Posted April 27, 2015 Posted April 27, 2015 Have you changed different oil than before? My sensor is located there too and currently it shows 40-50, because outside temp is only 0-5C. Quote
kbond Posted April 27, 2015 Author Posted April 27, 2015 No only difference from before on that side of things is I shortened the wires as was tiding the wires under the dash Nothing has changed engine wise Quote
MARC MOSS Posted April 28, 2015 Posted April 28, 2015 My gt used to sit at around 75-80 on a run and go up a little on a spirited drive but it's been in the garage a few days whilst I done some wiring and yesterday when I went out it didn't go over 65 what could cause it to be so low? And what is the average temp what it should be?Cheers keiransounds like a faulty sender unit mate, 75-80 is also low if you ask me...My m3 will happily sit at 100 and goes to 120 on track and thats the same as my dc2 as well. Quote
kbond Posted April 28, 2015 Author Posted April 28, 2015 It's a new sensor mate been on there 6months tops Quote
Socks Posted April 28, 2015 Posted April 28, 2015 The Outside Temps play a huge part in temps of oil/water dude ive found! Was it cold/hot then last time you tried? Quote
kbond Posted April 28, 2015 Author Posted April 28, 2015 No different to what it was time before Is 80 still to low then?My water sits at 75 but that's a double core rad with low temp thermostat so thought it was ok Quote
JayJ Posted April 28, 2015 Posted April 28, 2015 I would say 80 is ok for normal driving, but it really depends the oil you use. You should check the oil tech spec for shear point.I wouldn't go over 110c as usually the oils start to become ineffective. There are some oils though that will work higher temps. Quote
kbond Posted May 1, 2015 Author Posted May 1, 2015 Just need to find out why it's at 65 instead of 80 now thenMaybe order a new sensor as they aren't alot Quote
