I brought a ct9 from someone on hear to turbo my na as im sure most of you are sick to death about me asking questions ect lol
Anyway screetchy horrible sound on the way back from work got home took the intake off and exhaust and yep turbo shaft is all wobely as. So real question is do i get anothe ct9 or change it for something bigger ?
I take it you gone through all the right channels when turboing your na? And also why didn't you check the turbo before it went on
Yea it was working fine been about 3 weeks the turbo was 2nd hand when i brought it and it was ok when i recived it the shaft play nothing
Be as well sending that ct9 off to be rebuilt or inspected to see if it can be rebuilt. Chances are you will come across this problem time and again if you keep buying used ct9's. Rebuild would probably cost in the region of £200.
That's what I would do so only a suggestion buddy
John
What was it like when you put it on?
If its gone from minimal to loads in 3 weeks id be checking the oil feed/drain To see if theres a reason why it's gone bad so quickly Otherwise you'll be throwing money down the drain.
Disconnect your king lead so it doesnt start and just turn it over for a bit. Id also check the end of the feed where it goes into the turbo just incase thats the bit thats blocked.
I think you should be able to put that into a tub so it doesnt go everywhere.
cool ill give it ago before i put the new one on cant see the return beeing blocked ill poor some oil down the pipe to see if it drains throught
The drain should be fine tbh.
The other thing to ask is do you let in warm up and cool down after going for a blast to let the turbo cool? im guessing you do since you seem to know your way around a car.
