Year: 1997
Model: sportif turbo (properly converted with glanza loom and 4EFTE)
Tax: n/a
MOT: sept 2015
Mileage: shells on 127,000 and engine is unknown BUT has near perfect compression 170 over all four pots.
Description: sportif been properly converted and massive spec.handles amazingly well and goes seriously well also.
build thread says it all about how much works gone into this car.
SPEC LIST AS OF 15/05/15
HANDLING AND CHASSIS ENHANCEMENTS
# PRIVATE PLATE
# POLY BUSHED WISHBONES
# POLY BUSHED FRONT ANTI-ROLL BAR
# POLY BUSHED REAR BEAM
# POLY BUSHED ENGINE MOUNTS
# WHITELINE REAR ANTI ROLL BAR
# WHITELINE REAR ADJUSTABLE PANHARD ROD
# GT TURBO REAR DISC BRAKED BEAM
# TEIN MASTER MONO FLEX COILOVERS WITH CUSTOM SPRING RATES AND HELPER SPRINGS
# BATTERY RELOCATED TO BOOT
# WOLFRACE ALLOY WHEELS WITH NANKANG NS2R TYRES
# WEIGHT ADDED TO REAR WHILST STILL RETAINING SPARE SKINNY (55/45 WEIGHT DISTRIBUTION WITH HALF TANK FUEL)
# CUSTOM REAR CAMBER FABRICATED ( 2 DEGREES REAR CAMBER )
# MINTEX 1155 FRONT PADS
# HELL BRAIDED FRONT AND REAR BRAKE LINES
# RECENT BRAKE FLUID CHANGED FOR HIGH PERFORMANCE DOT 4 STUFF
# FRONT STRUT BRACE AND REAR THREE POINT STRUT BRACE
# 3D ALIGNMENT CARRIED OUT
# CHASSIS FULLY UNDERSEALED RECENTLY
# GAS STRUT TO OPEN BONNET
# FUSE BOX RELOCATED FROM ENGINE BAY TO GLOVE BOX
# UPGRADED EARTH POINTS
# OMP ALLOY PEDALS
# EXTENDED WHEEL BOLTS
ENGINE AND GEARBOX
# ZISCO CT9 RAM HORN MANIFOLD WITH EXTERNAL WASTEGATE AND CUSTOM DECAT TO SIDE-EXIT (TRACK FRIENDLY)
# THICK PURE COPPER TD04L GASKETS
# CUSTOM WATER LINES FOR TD04L
# SUBARU TD04L RUNNING @ 0.90 BAR
# CUSTOM 20MM ADAPTOR PLATE CT9/TD04L
# MANUAL BOOST CONTROLLER (PREFER MANUAL BOOST CONTROLLERS AS DONT FAIL)
# RECENTLY RENEWED IGNITION SYSTEM INCLUDING PLUGS,COIL PACK,ROTOR,DIZZY ETC
# RECENT FLYWHEEL AND 6 PUCK RACE CLUTCH
# SARD RRFPR (FUELING CONSTANTLY CHECKED WITH AFR GUAGE AND ALWAYS RUNS 11.00 AFR WHICH IS SAFE)
# FCD
# CUSTOM GAUGES FOR INTERCOOLER TEMPS,OIL TEMPS,WATER TEMPS,VOLTAGE,EXTERNAL TEMPS AND BOOST
# PERFORMANCE FILTER
# CUSTOM CHUNKY INTERCOOLER WITH CUSTOM PIPING
# BIG CHUNKY TRIPLE CORE RAD
# SMOOTHED ROCKER COVER
# CUSTOM CLEAR TOP CAM COVER
# MAGNETIC SUMP PLUG
every single piece of info is here
http://www.ukstarletowners.com/topic/72053-mikey4410-1998-starlet-sportif-turbo-rear-cambered-terror/
Price: 2,700
reason for sale is i fancy a rwd car and a new project.
Contact Details
email me mmmelling4410@gmail.com
Edited by mikey4410
thanks morgey.reason im thinking of selling is because I want a fresh new project,had this car coming up for three years and fancy a change. :-D
