Duduglanza Posted May 25, 2015 Posted May 25, 2015 As the title says it all.. my glanza was running fine. Dont know exectly if I have f***d it up or not but was trying to experiment something with my emanage ultimaye by using the sub inj map for my shift light. But couldnt find my way round. And removed all settings that i have changed.BUT NOW my glanza wint even fire up and if it runs it only does for seconds. I even disconected my emanage and running with standard ecu but still doesnt work.Any suggestions what to check? Quote
morgey Posted May 25, 2015 Posted May 25, 2015 Compression check. 150 or above?Set base timing. Were you driving it to test the shift light or reving it on the spot? Quote
Duduglanza Posted May 25, 2015 Author Posted May 25, 2015 Timing is left -10bdtc as normal. Didnt do any compression checks. I was experimenting in my garage therefore engine wasnt running. I did t even hook any shiftlight yet.Before tweeking some settings on the ultimate the engine was running superb fine! Quote
Duduglanza Posted May 25, 2015 Author Posted May 25, 2015 No no i chekcked various options.. i disconnected emanage.. changed injectors a tested fuel presures and spark.. everyhthing is running smooth. One thing i have in mind is trying the injectors outside to see if they spray normal.. Quote
morgey Posted May 25, 2015 Posted May 25, 2015 Any earths came loose, even something daft like HT leads given up the ghost Quote
Duduglanza Posted May 25, 2015 Author Posted May 25, 2015 I checked for spark and seems fine.. even earthing i double checked them. Im out of options Quote
Duduglanza Posted May 25, 2015 Author Posted May 25, 2015 Not at all.. but it only idles for few seconds then stalls. Therfore i cant sed if t smokes or not!.. i ran a diagnostics and no faults ard shown.. Quote
Socks Posted May 25, 2015 Posted May 25, 2015 Try unplugging the ICV, TPS, Coolant Temp Sensor. 1 by 1 and see if it improves anything? but yeh a compression test would be wise! Quote
Duduglanza Posted May 25, 2015 Author Posted May 25, 2015 (edited) I dont run icv since i have custom intakE. Regarding sensors I checked them through my emanage data logger. Map , water , intake anc tps sensors are all working good and giving good readings.I will try a compression test then altough i cannot heat the engine Edited May 25, 2015 by Duduglanza Quote
Duduglanza Posted May 25, 2015 Author Posted May 25, 2015 Its alive and i dont know what was the problem! :/ Quote
