Im getting boost creed what actuator will be best to go down to 0.5? Thanks its a racetech hybrid with standed actuator atm
Edited by Gumball89
Boost to
0.4 1st gear
0.4 2nd gear
0.5 3rd gear
0.5 4th
But in 5th doing 60/70 and i go to accelerate it climbs to just under 1.0 i obviously dont want this as not forged ect how can i stop this
What sort of intake do you have shorter route's usually cause creep there are other ways as Ollie has said. Good ecu map is a safe option, what set up do you want to achieve at what power? You can run 1 bar on stock internals with supporting mods..
might be worth getting an adjustable actuator - if you are using the stock actuator its more than likely knackered
Everything that makes a ct9 overboost lol
I have all that and mine doesn't go over .6 bar, used to creep to about .7 when I still had the tmic
Im probably going to try a hks actuator. But in the mean time as long as i moniter it i wont let it go over
Plug n play ecu actuator to 1 bar upgrade manifold it will be a different car the hks actuators are a stiffer spring the boost will just come in stronger. You can't go wrong with a plug n play just do abit more research.
