ROTABOOST Posted June 25, 2015 Share Posted June 25, 2015 Should have been checked as a baseline before mapping but as above id say it's pointing to timing. That would make it feel laggy too. Mine made 245hp @ 1.1! Quote Link to post Share on other sites
tommyep82 Posted June 28, 2015 Author Share Posted June 28, 2015 It's only a freashly built forged engine so should be no problem with compression, Going to change intercooler pipes and air filter and go back up to him. Can't think of much else, have to check dump valve as wel Quote Link to post Share on other sites
DevonGT Posted June 28, 2015 Share Posted June 28, 2015 On 6/28/2015 at 3:48 PM, tommyep82 said: It's only a freashly built forged engine so should be no problem with compression, Going to change intercooler pipes and air filter and go back up to him. Can't think of much else, have to check dump valve as wel Freshly built means nothing if it's been done badly. Only takes five minutes to check compression. Quote Link to post Share on other sites
tommyep82 Posted June 28, 2015 Author Share Posted June 28, 2015 Yeah I'm going to check during the week anyway. What size exhausts are other people running with this turbo to see good power? Quote Link to post Share on other sites
DevonGT Posted June 28, 2015 Share Posted June 28, 2015 2.5 or 2.75 inch ID will be big enough. Quote Link to post Share on other sites
gorganl2000 Posted July 1, 2015 Share Posted July 1, 2015 (edited) On 6/25/2015 at 8:21 PM, Foggy said: Ap performance dyno is also a low reading dyno. I have seen cars mapped on that dyno that made 200bhp and then to go on other dynos to make 220-230bhp. Aonghus mapping is flawless usually and spends more time than most getting cars right. i was about to say that it may just be the dyno....some places have low reading while others seem to have high on our local dyno i suspect you wouldn't make much over 170/180whp using a tdo4 at 1.2/1.5bar...on race gas maybe add on another 20/30whp when you say laggy,,,,is this on the dyno or on the road?? what rpm does it spool at and what rpm is full boost at? Edited July 1, 2015 by gorganl2000 Quote Link to post Share on other sites
Lewis. Posted July 2, 2015 Share Posted July 2, 2015 Aonghus dyno is known as the heartbreak dyno as it reads low/accurate. Take it to another dyno and you will see you lost power. All though personally if it drives well, i wouldnt care what figure it was. Anything aonghus maps will drive great on the road. Quote Link to post Share on other sites
tommyep82 Posted July 5, 2015 Author Share Posted July 5, 2015 Yes I know it's a low reading dyno but I still should of seen better power I think, it's not getting full boost till 4200 put pulls hard to redline starting to spool from 3000rpm, first few inches of my exhaust is only about 2 inches wide I think have to measure and change it, also have bad bend on an intercooler pipe so change them and try again I guess Quote Link to post Share on other sites
Calum122 Posted July 5, 2015 Share Posted July 5, 2015 We got a wepr TD04 Hybrid turbo that doesn't make boost till 4K mate. That idn't laggy. Even my CT9 doesn't make full boost till 4K mate so I'd say thats fine. My CT9 spools quickly but it doesn't mske full boost till 4K. Quote Link to post Share on other sites
wickedep Posted July 6, 2015 Share Posted July 6, 2015 it could be just the dyno mate. some do read low. you can always take it to another and do a power run. by the way full boost@4200rpm for a td04 hybrid is not laggy. sounds normal. Quote Link to post Share on other sites
