Need some advice here I want to get fairly large injectors it is currently a tdo4 with standered fuel rail (will be forging and bigger turbo eventually) anyone have any suggestions for a drop in 550+cc injectors that doesn't need resistors thanks
What ecu are you currently using? As that will ultimately determine how large you can go with it's actuation control.
I wouldn't go over 550's unless running a standalone.
