Ep82gi Posted July 21, 2015 Share Posted July 21, 2015 (edited) Right guys it might be a bad idea but could I use the live wire from a amp wiring kit to reallocate my battery? It come from a 2000watt amp kit Edited July 21, 2015 by Ep82gi Quote Link to post Share on other sites
MARC MOSS Posted July 21, 2015 Share Posted July 21, 2015 What size is the cable? Is it thicker than your battery cable? If so yes, just make good connections Quote Link to post Share on other sites
Ep82gi Posted July 21, 2015 Author Share Posted July 21, 2015 On 7/21/2015 at 3:34 PM, MARC MOSS said: What size is the cable?Is it thicker than your battery cable? If so yes, just make good connectionsThanks for the reply Marc It's about the same size if I'm honest dude only difference I can see is the coating used on it. Quote Link to post Share on other sites
_shaun_ Posted July 21, 2015 Share Posted July 21, 2015 ive used one but its a massive 0guage cable. just double check the thickness of the cooper some cheaper kits look nice thick wires when there actualy tiny and just a really thick coating Quote Link to post Share on other sites
Ep82gi Posted July 21, 2015 Author Share Posted July 21, 2015 I'll get right on that thank you very much. It come from a vibe kit so it should be half decent right? Or have I got that totally wrong? Quote Link to post Share on other sites
_shaun_ Posted July 21, 2015 Share Posted July 21, 2015 should be fine but the sizes can change massively between kits so worth checking doesnt take time todo so just peel the coating off like you would if you where fitting the kit anyway. Quote Link to post Share on other sites
Ep82gi Posted July 21, 2015 Author Share Posted July 21, 2015 Okay mate I will Do thank you very much is it as simple as just running the live from the battery under the car and connecting it to the live that would of been connected to the battery in the bay? Then earth it to a strut bolt in the back? What do I do with the earths that come off thee battery in the bay? Take them all out? Quote Link to post Share on other sites
RobSR Posted July 21, 2015 Share Posted July 21, 2015 2 AWG should be fine. Im looking to do mine shortly. Are people running inline fuses / circuit breakers? Heard people have just extended the wires and had no issues but wanted to check to see what others have done Quote Link to post Share on other sites
_shaun_ Posted July 21, 2015 Share Posted July 21, 2015 i have a fuse on the battery side and a kill switch in the bay. fuse for protection obv and kill switch makes it nice and easy when working on the car also made joining the battery cable and new cable nice and easy as it had to terminals that they just connected on. has actualy had alot of bonuses which i didnt think of either Quote Link to post Share on other sites
Ep82gi Posted July 23, 2015 Author Share Posted July 23, 2015 What sort of amp should I use then my one has a inline 60amp you recon that's up to the job? Quote Link to post Share on other sites
maddox710 Posted July 23, 2015 Share Posted July 23, 2015 I've been wanting to do mine for so long. What's the best way to secure the battery back there? I was thinking of chipping out the old battery tray once it's done to neaten the bay out Quote Link to post Share on other sites
Flaminsam Posted July 23, 2015 Share Posted July 23, 2015 Some 0 gauge or 2 gauge wire will be fine. Find a decent place to locate an earth in the boot and you will have no problems. Don't forget to make a bigger earth from the engine to the chassis as the cable will have gone from the negative on the original battery setup. I've got a kill switch in the car with 20 amp fuse bypassing it for the alarm. If you go to a auto electrical component suppliers and ask for 175 amp cable that will also be sufficient. Quote Link to post Share on other sites
Ep82gi Posted July 23, 2015 Author Share Posted July 23, 2015 On 7/23/2015 at 9:08 AM, Flaminsam said: Some 0 gauge or 2 gauge wire will be fine. Find a decent place to locate an earth in the boot and you will have no problems. Don't forget to make a bigger earth from the engine to the chassis as the cable will have gone from the negative on the original battery setup. I've got a kill switch in the car with 20 amp fuse bypassing it for the alarm. If you go to a auto electrical component suppliers and ask for 175 amp cable that will also be sufficient.Thanks buddy how can I tell what gauge cable it is? Thanks for the advise I'll get this done tomorrow Quote Link to post Share on other sites
Ollieh17 Posted July 23, 2015 Share Posted July 23, 2015 On 7/23/2015 at 8:26 AM, maddox710 said: I've been wanting to do mine for so long. What's the best way to secure the battery back there? I was thinking of chipping out the old battery tray once it's done to neaten the bay outI drilled holes in the boot,got a battery clamp with some threaded bar and bolted up both ends Quote Link to post Share on other sites
Flaminsam Posted July 23, 2015 Share Posted July 23, 2015 It should be printed on the cable the size of it.awg is an American measurement if I can remember right. Stands for amp width gauge. Quote Link to post Share on other sites
maddox710 Posted July 23, 2015 Share Posted July 23, 2015 On 7/23/2015 at 11:02 AM, Ollieh17 said: I drilled holes in the boot,got a battery clamp with some threaded bar and bolted up both endsGood idea suppose you could even use the toyota ones Quote Link to post Share on other sites
interloper393 Posted August 7, 2015 Share Posted August 7, 2015 Go to a breakers and ask for any bmw battery lines. There in the boot and you can get everything you need cheap Not sure the model mine came from but had fuses build into the cables, there longer cars so length will be fine too Quote Link to post Share on other sites
Ep82gi Posted August 7, 2015 Author Share Posted August 7, 2015 On 8/7/2015 at 5:16 AM, interloper393 said: Go to a breakers and ask for any bmw battery lines. There in the boot and you can get everything you need cheap Not sure the model mine came from but had fuses build into the cables, there longer cars so length will be fine tooI like that Idea mate Quote Link to post Share on other sites
