turbo-fever Posted August 3, 2015 Posted August 3, 2015 Right thinking of changing the EMU to a standalone setup as no one remotely near me will touch EMU. So is there a plug and play kit for the starlet I have heard about diypnp seems like a good choice.I'm not worried about loads of fancy options just a half decent plug and play kit that's easy to install ? Quote
H_D Posted August 3, 2015 Posted August 3, 2015 if you are going to buy a pnp ecu try to find a MINES ecu - they are supposed to be the best one for an ep82. Quote
Whitenoize Posted August 3, 2015 Posted August 3, 2015 if you are going to buy a pnp ecu try to find a MINES ecu - they are supposed to be the best one for an ep82. mines isn't a standalone ecu.. I think a apexi pfc would probe be a good option for what you need Quote
H_D Posted August 3, 2015 Posted August 3, 2015 mines isn't a standalone ecu.. I think a apexi pfc would probe be a good option for what you need I didn't say it was. Quote
Phil Posted August 3, 2015 Posted August 3, 2015 (edited) if you are going to buy a pnp ecu try to find a MINES ecu - they are supposed to be the best one for an ep82. aye stay away from Mines and the like, no use for simplicity powerFc is your best PNP option, but with a decent tuner he will build you a Link/Omex/Haltech pnp loom. id vote link. Phil Edited August 3, 2015 by Phil Quote
Whitenoize Posted August 3, 2015 Posted August 3, 2015 (edited) I didn't say it was. he's asking for a plug and play standalone so mines is hardly relevant as an option Edited August 3, 2015 by Whitenoize Quote
Phil Posted August 3, 2015 Posted August 3, 2015 he's asking for a plug and play standalone so mines is hardly relevant as an option wrong end off the stick is all i think pal. no harm no foul Phil Quote
turbo-fever Posted August 3, 2015 Author Posted August 3, 2015 I've heard link are quite expensive and omex is cheap and chearful, will mappers touch the apexi ? Quote
Phil Posted August 3, 2015 Posted August 3, 2015 (edited) Link G4+ atomCheap and top qualityPhil Edited August 3, 2015 by Phil Quote
H_D Posted August 3, 2015 Posted August 3, 2015 he's asking for a plug and play standalone so mines is hardly relevant as an option Sorry. my bad im a bit dyslexic. Quote
Whitenoize Posted August 3, 2015 Posted August 3, 2015 Sorry. my bad im a bit dyslexic. I wasn't having a go mate sorry if it came across that way Quote
turbo-fever Posted August 3, 2015 Author Posted August 3, 2015 Would mappers in Essex be able to map the link ? Take it it's the same as any standalone Quote
Stu Posted August 5, 2015 Posted August 5, 2015 Link G4 Atom would be a great option - but really you need to talk to who ever will tune it and find something they are comfortable with. Quote
turbo-fever Posted August 6, 2015 Author Posted August 6, 2015 Spoke to Colin at atspeed he has done 3 starlets with omex but works out over 1400 so not as cheap as I wanted Quote
Stu Posted August 6, 2015 Posted August 6, 2015 Any other good tuners around your area? Just shop around if you can. $1400 doesn't seem bad if its installed and dyno tuned. Quote
Bussey Posted August 6, 2015 Posted August 6, 2015 Would mappers in Essex be able to map the link ? Take it it's the same as any standaloneRedline in Basildon specialise in all the LINK stuff Quote
turbo-fever Posted August 6, 2015 Author Posted August 6, 2015 Bussey you the fella I met last night in Southend ? Quote
