ok so I have seen a few threads on this but no one really saying what I need to know.
My stock CT9 needs replacing, I was just going to replace with a reconditioned stock CT9 but also wanting to go with a TD04 in the future.
So to save me spending money on a CT9 that will only be in there for 6 months or so could I put on a TD04 but keep the boost at stock pressures (0.6 bar I think?)
So my question is can I run a TD04 on stock EVERYTHING so ecu, fuel pump, the lot as long as I'm not adding any more boost. I'm not on the hunt for power just yet, just a working car
Thanks for any input
Ran 0.8 bar on a td04 on glanza, standard ecu etc same as you. Fuelled fine, i did have a wideband though
Edited by Ollieh17
Going with an Tia 38mm external wastegate so if I put in the spring for 0.5 bar I will be fine until I get a new ECU, FPR and file pump ? In which case I can add a boost controller to set it to what I need
