I've removed my intercooler and noticed that there is some oil left in the hose which connects to the inlet manifold and was wondering is there supposed to be oil in there?
Edited by Countryman
Yes the turbo was gone so I'm just replacing it.
How would I clean it out and is there anything else I need to be on the lookout for just incase oil has got in else where?
I'm changing the mani, turbo, decat and intercooler.
Cheers
remove it remove all the necessary bits throttle body idle control valve and leave it soak in kerosene (red diesel)
get yourself a few cheap brushes and give it a good cleaning you might want to give it a power wash afterwards to get it really clean but should be ok leave it to dry then refit it
  • 2 weeks later...
As long as theres not too much oil i wouldnt worry, just wipe away any heavy amounts and put it back together. The breathers on the valve cover go to the inlet and take oil vapor and throw it back in the engine anyway.
Maybe check for a build up around the throttle butterfly and give that a clean but it shouldn't be much to worry about.
