Bug679 Posted August 18, 2015 Posted August 18, 2015 Hello again folks So looking at my catch can , I seen it is full of water a few bits of sludge in as well, just wondering is this normal seems to be quite a lot. This is about a month this has happened. Does it look normal Quote
StuDoc 72 Posted August 18, 2015 Posted August 18, 2015 Is your anti-freeze red Im guessing? If so then nah that's not good. Quote
Bug679 Posted August 18, 2015 Author Posted August 18, 2015 No anti freeze is green 😟 what could it be, the oil isn't mixing with water in engine it's just oil not cloudy at all Quote
StuDoc 72 Posted August 18, 2015 Posted August 18, 2015 Where did the orange come from then lol. Probably just as dan said then wouldnt sweat it. Quote
Bug679 Posted August 18, 2015 Author Posted August 18, 2015 Don't know lol. Probably just a bit of oil colouring it then. Not so bad I'll leave it for a month or two see what it's like then. Cheers lads Quote
Bug679 Posted August 18, 2015 Author Posted August 18, 2015 Dead on I'll keep an eye on it anyway. New to these catch cans and taught it looked a bit funny was all. Quote
Arnold Posted August 18, 2015 Posted August 18, 2015 (edited) Do you have any build up inside the filter bit too? Mine is open to atmosphere and a ton of gunk has come out all over my nearside wishbone Edited August 18, 2015 by Arnold Quote
StuDoc 72 Posted August 18, 2015 Posted August 18, 2015 So the water is just condensation which would naturally build up over night. When you start your engine it heats up and boils then it rises and escapes through your breathers and into the catch can as it should. Confirming its not antifreeze then its working as it should. The reason there is emulsified oil is because thats what happens when water makes prolonged contact with oil. Obviously the breathers are there for the engine to breath inside the engine is oil. Therefore it is inevitable that some oil will work its way through these pipes then sit in the catch can where it will emulsify. All in all, Its Sound Quote
Bug679 Posted August 18, 2015 Author Posted August 18, 2015 Sound lads, thanks for the replys and help 😀 Quote
5T4R7ET N/A Posted August 19, 2015 Posted August 19, 2015 This happened to me during the colder winter months, you will have to keep an eye on it and drain your catch can, pretty annoying. Quote
Bug679 Posted August 19, 2015 Author Posted August 19, 2015 As long as there's nothing wrong with the engine I'll empty it once a week lol 😀 Quote
StuDoc 72 Posted August 19, 2015 Posted August 19, 2015 Empty it when it fills up thats the idea is it not? Quote
Johnboy GT Posted August 19, 2015 Posted August 19, 2015 Can always plumb it back to standard and have it sit in the engine or on the rocker.... Quote
Bug679 Posted August 19, 2015 Author Posted August 19, 2015 Lol I'll leave it be and just empty it thanks again Quote
