ok so I've decided to put my car completely back to standard so after a fair few standard parts will do a list bellow if you have any of the parts I'm after pm me Please
Standard king lead
Toyota front mats
Flare
Standard glanza alloys
Un cut 96 spec bumper
Standard exhaust manifold heat shield
Think that's about it cheers
Edited by Whitenoize
I've got a 96 center console and jdm main starter motor feed cable mate, pm me
is it just a plain black centre console mate can you put a picture up please and by starter motor cable does it have the battery terminals on it ?
Thanks Ryan
The center console is dark grey mate. its from a 96 jdm glanza turbo
ill try and get a pic when im at work later
the starter feed cable has the live battery terminal on one end and a ring for the starter on the other end
i dont think ive got the earth cable but ill have a look
you will prob need the full cables as its not easy to join the batt terminals on properly
also do you want to sell the blue magnecors, socks has a set of red trds you could buy or i know a guy on the paseo forums with a set aswell
Cheers, Jim
Well lad i have 2 front cusco topmounts, there is a bit of play in one of them, and slight oxidation in patches,also have battery terminals, and should have center console aswell man, pm if interested
I've updated the list thanks to everyone who has sorted me out with parts one way or another bumping this up really need a fpr before I go order one from td
Ah fuck yeah I forgot to get them pictures for you dude sorry I will snap some tomorrow I got a centre console for a fiver mate so couldn't really turn it down
I believe I have a standard top mount and brackets in the my garage somewhere I will have a look later and let you know if you still need one :-)
that would be great dude thanks
Got loads of the parts I needed from a member list ammend bump for any other parts could really do with a standard king lead and the 2 ct9 water hoses
If your really stuck mate you can always use fuel lines think it's about 6mm line you need just to tied you over for now had to do this to one of mine due to a split pipe
Got the turbo to ic pipe mate
awesome mate pm me how much you want for it and your PayPal you don't happen to have the tmic rubber connector hoses ?
