Loads of standard parts
ok so I've decided to put my car completely back to standard so after a fair few standard parts will do a list bellow if you have any of the parts I'm after pm me Please
Standard king lead
Toyota front mats
Flare
Standard glanza alloys
Un cut 96 spec bumper
Standard exhaust manifold heat shield
Think that's about it cheers
Edited by Whitenoize
I've got a 96 center console and jdm main starter motor feed cable mate, pm me
is it just a plain black centre console mate can you put a picture up please and by starter motor cable does it have the battery terminals on it ?
Thanks Ryan
The center console is dark grey mate. its from a 96 jdm glanza turbo
ill try and get a pic when im at work later
the starter feed cable has the live battery terminal on one end and a ring for the starter on the other end
i dont think ive got the earth cable but ill have a look
you will prob need the full cables as its not easy to join the batt terminals on properly
also do you want to sell the blue magnecors, socks has a set of red trds you could buy or i know a guy on the paseo forums with a set aswell
Cheers, Jim
If your really stuck mate you can always use fuel lines think it's about 6mm line you need just to tied you over for now had to do this to one of mine due to a split pipe
