Need a crank pulley, have a choice between the lightweight one from fensport or a standard one.. Is it worth the extra money for the lightweight one?
its pretty easy to tell despite the fancy name its basicly a rubber strip sandwiched in the middle of the pully to absorb any vibration or so i understand. personally wouldnt bother with a light weight one although if you ditch pas you can get the n/a one which weighs half the weight am sure it was around 800g from memory.
Edited by _shaun_
