glanzadude Posted August 26, 2015 Posted August 26, 2015 I got my new gearbox fitted over the weekend but the only thing is it pops out off 4th and only that gear? What's that from and how to fix it? Thanks Quote
ToyotaTech15 Posted August 27, 2015 Posted August 27, 2015 Most likely a worn syncro or syncro hub, only way to inspect is to strip gearbox Quote
glanzadude Posted August 28, 2015 Author Posted August 28, 2015 I also fitted poly engine mounts at the same time I would be really surprised if the gearbox is damaged Quote
JDMfreak Posted August 29, 2015 Posted August 29, 2015 ive after fitting poly mounts in mine hasn't affected the gears Quote
glanzadude Posted August 29, 2015 Author Posted August 29, 2015 Really ok must be the box so balls Quote
akyakapotter Posted August 29, 2015 Posted August 29, 2015 check the spring on the gear shifter mine had snapped causing mine to pop out of 5th for a while Quote
glanzadude Posted August 29, 2015 Author Posted August 29, 2015 I have a short shifter to if that has anything connected to it sliding out off gear? Quote
akyakapotter Posted August 29, 2015 Posted August 29, 2015 I have a short shifter to if that has anything connected to it sliding out off gear? mines a short shifter bud there is a spring that brings it back to center when you select a gear mine had snapped. Quote
glanzadude Posted August 29, 2015 Author Posted August 29, 2015 I had a look just there not that Quote
