GlanzaJ Posted September 2, 2015 Posted September 2, 2015 Evening guys , recently my head gasket blew on glanza and having been building it back up over last month or so. Had the head sent off to be skimmed and had the valve clearances adjusted. Started the car today and it ran on idle for around 2-3 mins , gave it a little throttle and died. I haven't been able to get it running since, everytime it's cranked over the spark plugs are soaked in fuel. Dry them off and try again and almost starts untill there soaked again. I've checked fuse's, vacuums, leads, dizzy, fpr, had the fuel rail off. I hear that taking the thermostat off can interfere with fueling Incase it helps the car is running e-manage blue any help would be great , jamie ! Quote
Johnboy GT Posted September 2, 2015 Posted September 2, 2015 Hoses on the back of the inlet manifold on the correct way round?John Quote
GlanzaJ Posted September 2, 2015 Author Posted September 2, 2015 That did go through my mind, what gets me is that was running perfectly untill i revved it Quote
GlanzaJ Posted September 2, 2015 Author Posted September 2, 2015 After having a little think , could it be timing related Quote
Stu Posted September 3, 2015 Posted September 3, 2015 Water temp sensor for the ecu plugged in and working? Any ecu codes? Quote
GlanzaJ Posted September 3, 2015 Author Posted September 3, 2015 No codes on ecu, going to check the plugs on thermostat ,why would it stop it from running ? Quote
Stu Posted September 10, 2015 Posted September 10, 2015 If the water temp sensor isn't plugged in the ecu thinks the engine is dead cold (what ever the coldest temperature is on its compensation tables) and will generally throw a shit ton of fuel at the engine for crank enrichment and cold start enrichment till its warm. Ive found some Toyota ecus wont start if the water temp sensor is unplugged or faulty. Likely not the cause but worth checking. Quote
Gainzy Posted September 10, 2015 Posted September 10, 2015 Try and bump start it could be starter motor.. Quote
ToyotaTech15 Posted September 10, 2015 Posted September 10, 2015 2nd Stu's post, i had the same fault with a mk2 MR2, was a knackered coolant temp sensor causing excess fuel at start and it wouldn't start Or at least it did start when i took plugs out and cleaned but still took a while. Was the thermostat in place when you sent the head away? Quote
GlanzaJ Posted September 14, 2015 Author Posted September 14, 2015 was dizzy cap , cheers lads ! Quote
