Just received my defi tacho today, downloaded the Pdf wiring diagram and plumbed it in. Everything then got setup as to the manual so I started the car and it all worked fine. This was until I revved the car anyway...
The tachos response is terrible and very slow in comparison to the standard gauge and my apexi gauge which is quite odd. I have also removed all of the other gauges from the wiring just to see if they were causing the problem but it's still really slow to react :( I'm gonna nip out again and wire the earth directly to the battery but I'm pretty sure the earth I have used is completely fine.
I have been an automotive electrical engineer for years now and this shits doing me in
Just earthed it straight to the battery and it's still the same, it's setup on 4 cylinder mode as well. I just took it for a drive and it seems better then when just revving it in neutral but is this normal?
Like this slow? If so could be fake.
https://youtu.be/Lauo5548IPI
That's the shit, fucking bollocks the first and second stage warnings etc work perfectly and it's very well built.
I hate fake shit best have a word with the seller
maybie dodgy signal ??? where did you tap in on your teg ?? dizzy or ecu ??
Straight to the ecu mate
