So I pulled the air con out at the weekend and put in my civic rad, now my gt seems to get cold while driving. Gets up to temp when stood still but driving along cools it down.
Never did this before so it won't be thermostat, is it to do with the sensor out of the a/c? Without it plugged in the fan was always on,.
Or something else?
I would still check your thermostat as the first point of call, the fan running when driving shouldn't make that much difference as there is plenty of air already going through. To me it deffo sounds like the thermostat sticking open
I know it sounds like the thermostat but it's happened directly from taking the a/c out and changing the rad, fan isn't on constantly as I have the sensor out of the a/c pipe plugged in, I'm wondering if that has anything to do with it as I didn't just bridge it
I left mine plugged in and didn't bridge it but i did have this issue when i removed my aircon. It was the thermostat. they're cheap to replace so might be worth just trying a new one, or test yours in a cup of boiling water only 4 bolts to remove it iirc
Ah right ok, strange coincidence that it was fine before, are they same as a uk spec thermostat? because obviously no parts factors will have a clue what the car is
But yes I bled all the system, did used to be a mechanic a few years ago aha
Edited by dan106
It'll be one of those situations where it was all fine, but by changing one thing, it's disturbed the rest. For the few quid they cost, and the quick job, I would just change it to be sure
Yeah I looked already the website says they've not got any in stock, will probably order when I get payed as I need service bits anyway
Well good news, seems to of sorted itself, maybe there was still a bit of in the system, still gonna get a thermostat when I service it mind
