Help. turn on ventilator and it throws mess P8
Since i have my car for a over a year it's not a pleasure to turn the fan on. Cause when i turn it on a lot of mess is coming out my ventilation. Like sand, leaves and dead flies.
Does anybody have or got the same problem and found a solution for it? Cause so far i know the P8 doesn't have any filter or smtg so it comes from outside, just in front of the window.
get your self a lend of a good hoover with an extension piece pop the vents pop out and stuff the hoover down them should suck up a good bit of the crap stuck there if you can leave the blowers on full blast cold will do to push any crap nearer the hoover
