tommcnaught Posted September 21, 2015 Posted September 21, 2015 Just rebuilt engine and started it as soon as I did I noticed it chuck a lot of smoke out the exhaust (thought this could be condisation) after 30seconds I thought it seemed to much so turned off and checked oil cap and its milky, was only running fr about a minute max didn't even get warmAny common issues on a rebuilt engine that could cause thisOemHeadgasket and head was skimmed although headgasket never went before rebuild Quote
Ollieh17 Posted September 21, 2015 Posted September 21, 2015 Vac lines on the wrong way on throttle body Quote
tommcnaught Posted September 21, 2015 Author Posted September 21, 2015 Vac lines on the wrong way on throttle bodyGot a pic of which way around they should be? Quote
kbond Posted September 21, 2015 Posted September 21, 2015 As above its really easy to do I've done it myself there is an old thread somewhere with pics in there showing the right way around Quote
daniel_g Posted September 21, 2015 Posted September 21, 2015 Here you go dudeWish i had a quid for every time ive linked this haha Quote
Whitenoize Posted September 21, 2015 Posted September 21, 2015 😂 you need a copyright on that picture Dan Quote
tommcnaught Posted September 21, 2015 Author Posted September 21, 2015 Here you go dudeWish i had a quid for every time ive linked this hahaIdeal cheers mate Quote
daniel_g Posted September 21, 2015 Posted September 21, 2015 you need a copyright on that picture DanI know man haha If only people would see it before its too late! Quote
tommcnaught Posted September 21, 2015 Author Posted September 21, 2015 I know man haha If only people would see it before its too late! i had these 2 hoses wrong way around but aren't they both vac hoses? Quote
daniel_g Posted September 21, 2015 Posted September 21, 2015 i had these 2 hoses wrong way around but aren't they both vac hoses?No, some are water hoses.You will have put coolant through your oil. Do a oil and filter change, maybe an engine flush aswell if you want to. Hopefully it will be fine after that. Quote
