maybe its normal or maybe i have slipped up somewhere but should it be simple to fit the clutch slave cylinder to the gearbox after the gearbox has been mounted to the engine? serious pressure on the clutch fork when i try pull it back to fit slave cylinder... where have i made my mistake or is this normal??? ep91 with trd lsd and excedy stage 2 clutch
you can push in the rod by hand even when its fully bled
i fit them by putting the rod on the piston fork and push a tat then screw in your 2 screws smple job no need to open the nipple because you will have to bleed it again
  • 3 weeks later...
