Sign in to follow this
Pikey009
Glanza rear strut brace.
I'm not bothered about it bolting to the floor just if it will actually fit in place
Share this post
I'll be keeping the rear seats ha ha but thanks. I guess I'm kind of after Toyota option parts for the Sr as I don't want to stray too,far away from factory looking stuff
Share this post
The glanzas have extra mounting plates on the strut tops for the brace that the N/As dont have so as Morgey says the bolt holes would be out.
Hi lads - how do you make the glanza OEM rear strut brace to fit on N/A EP91 so? !PLEASE HELP!
I have bought the 3 point glanza one (price was really good and has all the plastics! just needs painting as it's blue...). The plan was to fit it this X-mas but I didn't know that it won't fit...;(
Regarding the 90deg rotated fittment of top mount (as per photo below):
- Is it possible to drill another 2 holes (is it enough room there?) on top of each strut tower and bolt it that way?
How is the middle bottom part sitting then against the beam/back seat?
I've found out that glanza has an extra factory bracket there (see the part number 58225-10020 as per pictures below) but I'm sure someone has already done this excercise on N/A EP91 without this part and can tell me would couple of washers or 100x20x20mm(say) steel plate do ?
Strut tower top:
Center bracket: (I wonder can I order it from local dealer...)
What I also found this:
http://austarletclub.com/index.php?/topic/18747-how-to-glanza-rear-strut-brace-in-aus-spec-ep91/
but I don't think I'd go for re-welding!;(
Cheers and thanks in advance for all the help - I really want to fit this OEM brace instead of selling it and getting cusco..
Edited by Di_Bodi
Share this post
Cheers mate!
I'll try to get as much advice as possible from other lads here before I give up... I'm sure it can be done!
Share this post
I gave up and got a cusco- sprayed it black for a bit more of a factory look
How did the cusco fit? Just bolt on or you had to cut some plastic out? Have you managed somehow to put them top covers back in place?
Share this post
You have to trim a bit as its quite low to the base of the strut tops. I never tried getting my plastics back on top but with a bit of fiddling and trimming i think you could get them on
Share this post
Are the towers or mounts higher in glanza then in n/a???
some photos of my strut bar:
Lovely condition boot;) - I'm not too sure would I ever cut any plastics there!!
not only the alignment is the problem but the hight as well! It's sittin gon the plastic so I'd need to rise the hole bar up? How it comes the glanza has it right?!?
alignment:
The bottom plate seem to be at strange angle (not level to floor) and hopefully the seat hinge won't be on the way!
Who has it fitted - PLEASE HELP
Edited by Di_Bodi
Share this post
Wow I never knew they were that far off- I missed out on one by £1 on eBay last month! Trimming the plastics isn't too bad mate. If you've got a dremel then it's fairly easy just measure and take your time cutting. I cut the basic outline using the mini cutting blade and then using the mini sander to neaten and trim a little more as I went. That way I didn't over cut the plastics.
The covers won't fit back on as standard but i was thinking of trimming them to see so I'll let you know.
Share this post
Thanks lads!
Also if you know who has the glanza brace fitted in n/a - let me know, I have to ask them how did it go!
Share this post
The extra glanza studs are raised about 8mm above the top of the strut tower in an extra little cage.
As for the floor i think Glanzas have solid rear bench so no hinge in the middle?
Share this post
