mark-tozer Posted November 9, 2015 Posted November 9, 2015 (edited) Currentley I have a spec 6 puck un sprung clutch kit. I've never been overly happy with it from day one the clutch release bearing has been making a noise. I recently did a track day at llandow and last session out i lost drive so assume the clutch release bearing has let go and possibly damaged the clutch I havnt striped it out yet. What's is the best clutch for me to get don't mind spending money just want somthing that actually does it's job and lasts I've only been running 1 bar on track aswell with td04 so not big power considering the spec is rated to like 300ftlbs or torque. I've been doing a bit of digging and see os girken or Orc. What do you recommend thanks Edited November 9, 2015 by mark-tozer Quote
RobSR Posted November 10, 2015 Posted November 10, 2015 id recommend an ORC, its what i have in mine. That said they do make abit of noise when the pedal is depressed so you may not like it. Quote
akyakapotter Posted November 10, 2015 Posted November 10, 2015 Os giken is rated to the most power and torque orc and blitz are rated to 296hp 250 ftlb torque. Looked into it when my spec was annoying me. when mine needs replacing it will more than likely be with an Os giken Quote
mark-tozer Posted November 10, 2015 Author Posted November 10, 2015 (edited) id recommend an ORC, its what i have in mine. That said they do make abit of noise when the pedal is depressed so you may not like it. thanks for getting back how long have you had this clutch what torque are you running ? Does it make a noise when it's just sat there in neutral stationary.would like a clutch that's quiet but if it lasts and does it's job that's the one to have. Thanks. Orc Os giken ok thanks which one have you had experience with. Edited November 10, 2015 by mark-tozer Quote
mark-tozer Posted November 10, 2015 Author Posted November 10, 2015 Os giken is rated to the most power and torque orc and blitz are rated to 296hp 250 ftlb torque. Looked into it when my spec was annoying me. when mine needs replacing it will more than likely be with an Os giken ok thanks where did you find was best to buy one nengun or rhdjapan. Quote
Phil Posted November 10, 2015 Posted November 10, 2015 Blitz active and Orc 309From my experience and that of a pal they are pretty identical Currently using the blitz and when it's beat I'll hopefully get it refurbed and stuck back onPhil Quote
akyakapotter Posted November 10, 2015 Posted November 10, 2015 When I was looking mark I was on rhd works out about £600 ish landed there are a few os giken ones on there Quote
Jamie_VF22 Posted November 10, 2015 Posted November 10, 2015 Had an orc 309 great clutch and yea they make a noise when the pedal is depressed Quote
mark-tozer Posted November 10, 2015 Author Posted November 10, 2015 Blitz active and Orc 309From my experience and that of a pal they are pretty identical Currently using the blitz and when it's beat I'll hopefully get it refurbed and stuck back onOk thanks for your help. Phil Quote
mark-tozer Posted November 10, 2015 Author Posted November 10, 2015 When I was looking mark I was on rhd works out about £600 ish landed there are a few os giken ones on there ok thanks I'll have a look around at prices again is there no English company that can supply. Quote
Phil Posted November 10, 2015 Posted November 10, 2015 Blitz active and Orc 309From my experience and that of a pal they are pretty identicalCurrently using the blitz and when it's beat I'll hopefully get it refurbed and stuck back onOk thanks for your help.Philno problem mate Quote
mark-tozer Posted November 10, 2015 Author Posted November 10, 2015 Had an orc 309 great clutch and yea they make a noise when the pedal is depressed ok good to hear it's a good clutch. I can deal with it making a noise when the clutch is pressed as long as it lasts. How did you find yours wear. Quote
akyakapotter Posted November 10, 2015 Posted November 10, 2015 You could possibly ask one of the import companies they may be able to sort it out for you or some one on here who imports stuff from Japan Quote
Jamie_VF22 Posted November 10, 2015 Posted November 10, 2015 (edited) ok good to hear it's a good clutch. I can deal with it making a noise when the clutch is pressed as long as it lasts. How did you find yours wear. About 3 years hard driving mate Had launch control activated on my EMU on my old set up so got some stick mate Edited November 10, 2015 by Jamie_VF22 Quote
RobSR Posted November 10, 2015 Posted November 10, 2015 Yes they only make noise when the pedal is depressed. If idling in neutral its fine. Mine was off RHD was about 580 shipped i think. Quote
mark-tozer Posted November 10, 2015 Author Posted November 10, 2015 About 3 years hard driving mate Had launch control activated on my EMU on my old set up so got some stick mateok that's good to know thanks for your help. Quote
mark-tozer Posted November 10, 2015 Author Posted November 10, 2015 Yes they only make noise when the pedal is depressed. If idling in neutral its fine. Mine was off RHD was about 580 shipped i think.ok I can deal with that if it's just when it's pressed isn't the end of the world. Ok thanks for help Quote
Bean Posted November 10, 2015 Posted November 10, 2015 look at the helix ones. i had a helix paddle in my ep85 and it was spot on, plenty of launches at the drag racing and pedal wasnt hard like others. I have since fitted one in my gt4 and its great in that too. Quote
mark-tozer Posted November 10, 2015 Author Posted November 10, 2015 look at the helix ones. i had a helix paddle in my ep85 and it was spot on, plenty of launches at the drag racing and pedal wasnt hard like others. I have since fitted one in my gt4 and its great in that too. ok I'll have a look at helix one where did you get yours from thanks Quote
Bean Posted November 11, 2015 Posted November 11, 2015 Fensport sell them that's where I got the gt4 one. Quote
mark-tozer Posted November 11, 2015 Author Posted November 11, 2015 Fensport sell them that's where I got the gt4 one.ok thanks Quote
