Vturbo Posted November 9, 2015 Posted November 9, 2015 so, I'm planning to run around 1.4 bar on a TD04, what heat range plugs do people use? Thanks! Quote
jayc-glanza17 Posted November 9, 2015 Posted November 9, 2015 I run heat range 8 dude..Used to run them when i was td04 back in the day Quote
Socks Posted November 10, 2015 Posted November 10, 2015 @AdamB Grade 8 or 7? Pros Cons of each in your opinion? Quote
Vturbo Posted November 10, 2015 Author Posted November 10, 2015 (edited) I ran 7s at 1 bar on ct9 hybrid..had a few people tell me 8's for the td04 setup. Edited November 10, 2015 by Vturbo Quote
Stu Posted November 10, 2015 Posted November 10, 2015 BKR7e - gap to 0.8mm or so. They will run a lot more than 1.4bar with no problems and they are miles more forgiving that iridums Quote
AdamB Posted November 10, 2015 Posted November 10, 2015 @AdamB Grade 8 or 7? Pros Cons of each in your opinion? Their 7's mate, the grade is in the part number. 8's are way too cold for a td04, wouldn't start using 8's till like 400bhp or running exotic fuels. Or as Stu suggested, run the copper core plugs, but they need changing more frequently. Quote
Amjad Posted November 10, 2015 Posted November 10, 2015 How long are coppers good for? Changed from Iridium to Copper a few months ago on mine Quote
AdamB Posted November 10, 2015 Posted November 10, 2015 (edited) I'd probably change them every 25k, or every 2 services. I change my Iridiums every 25k just to keep things fresh. Inexpensive service item that gets changed regularly rules out any problems in the future Here's a little piece of tech info. Spark plugs, common item and often overlooked.http://www.ngk.com.au/spark-plugs/technical-information/heat-range-explanation Edited November 10, 2015 by AdamB Quote
Chief Quimby Posted November 22, 2015 Posted November 22, 2015 I use standard plugs from 4age 16v, 0,6 gab on my 400hp 5efte Quote
Stu Posted November 22, 2015 Posted November 22, 2015 (edited) Yeah they run the same plug, would think your running a colder BKR7e or even an 8 for that boost? Edited November 22, 2015 by Stu Quote
Chief Quimby Posted November 24, 2015 Posted November 24, 2015 Me ?, i use the bone stock ones from 4age at 2,3 bar. Quote
Phil Posted November 24, 2015 Posted November 24, 2015 (edited) Fiesta ra turbo copper plugs Cheap as chipsBcr8es (Thanks for part number Chris )Phil Edited November 24, 2015 by Phil Quote
Phil Posted November 25, 2015 Posted November 25, 2015 Just priced them and they are £10 for a setPhil Quote
GP82 Posted November 25, 2015 Posted November 25, 2015 Horse power level and boost pressure ratio do play a part in selecting the right plug heat range, but actually it's a combination of all, more so the heat thats created from combustion. For example you could have a high compression engine producing 180hp but would still require relatively colder spark plug then a lower compression engine producing 280hp. Quote
AdamB Posted November 25, 2015 Posted November 25, 2015 Horse power level and boost pressure ratio do play a part in selecting the right plug heat range, but actually it's a combination of all, more so the heat thats created from combustion. For example you could have a high compression engine producing 180hp but would still require relatively colder spark plug then a lower compression engine producing 280hp. That's the issue, peak cylinder pressures and temperatures. Because the 4E is so low on compression there's no need for cold spark plugs. Quote
