morgan Posted November 10, 2015 Posted November 10, 2015 I have a wepr ct9 power up kit on the way but I know that it is not a stock location manifold set up. I have a braided oil line going to the turbo which should be plenty long enough to fit but I'm worried that the rubber hose that connects to the return pipe off the turbo to the dump won't be long enough, has anyone got the same kit, if so where did you get your hose from or do you know if the stock one can me used ? Quote
morgan Posted November 17, 2015 Author Posted November 17, 2015 Can anyone tell me where to get a good quality hose from? Just need it to go from the turbo oil outlet to the sump as the factory hose does not reach any more. I have been told silicone will be ok and others say it won't due to the high temperature of the oil Quote
Ollieh17 Posted November 17, 2015 Posted November 17, 2015 I used the factory hose on my kit Silicone will be fine just make sure ita fluro lined Quote
morgan Posted November 17, 2015 Author Posted November 17, 2015 I have been told that the factory hose will be too short as this kit is non stock location, any idea where to get Fluoro lined silicone bends ? Quote
funny onion Posted November 17, 2015 Posted November 17, 2015 Just go on ebay and search for it, i got a meter length for my top mount kit and cut it down to the right size. Quote
adzy Posted November 17, 2015 Posted November 17, 2015 The ct9 power up kit comes with a new oil feed/return to suit the new location, so my guess is it will allow the factory rubber pipe to be used.Not 100% sure as I'm waiting on my kit too Quote
5T4R7ET N/A Posted November 17, 2015 Posted November 17, 2015 If you want fluoro lined then its not cheap,Viperperformance.co.uk Quote
morgan Posted November 17, 2015 Author Posted November 17, 2015 I didn't get the oil line with my kit because I have a brand new braided line so I do know the i will need a longer pipe. Any one know anything g else I can use ? Just want a rubber hose tbh that works with hot oil Quote
Ollieh17 Posted November 17, 2015 Posted November 17, 2015 For a ct9 the braided oil line should be attached to the oil return. People have said what you need to use, just get on ebay and find a silicone bend Quote
ChrisLeeBoost Posted November 17, 2015 Posted November 17, 2015 Auto silicone hoses on eBay where I got mine, 19mm to 16mm reducer is what you need for oil return and they are fluoro lined aswell Quote
Ollieh17 Posted November 17, 2015 Posted November 17, 2015 Auto silicone hoses on eBay where I got mine, 19mm to 16mm reducer is what you need for oil return and they are fluoro lined aswell thats for td04 Quote
ChrisLeeBoost Posted November 17, 2015 Posted November 17, 2015 Thanks Ollie bit of a blonde moment there never read the mans thread properly! Quote
