Ep82gi Posted November 24, 2015 Posted November 24, 2015 So my drivers front windows given up the button works fine but the window doesn't go up or down under the power of the motor I have to move it by hand. Has anyone had this before? If so could you tell me the possibilities it could be as I drive the car daily I can't really spend the day pulling my door apart due to work. Thanks Liam Quote
fiddlersport Posted November 29, 2015 Posted November 29, 2015 motor packed up ! suppose to be common problem i heard Quote
geofreygachie Posted December 18, 2015 Posted December 18, 2015 I am also having a problem almost similar, the drivers front window system is erratic and sometimes it works sometimes it doesn't.I have also noted that the front passenger door doesn't lock when i use central locking system. Quote
Ep82gi Posted December 18, 2015 Author Posted December 18, 2015 motor packed up ! suppose to be common problem i heardSorry buddy only just noticed this my motor still works as I can hear it spinning but doing nothing any idea how to fix it? Quote
Amjad Posted May 13, 2016 Posted May 13, 2016 Bumping this, did you solve it? My window goes down but doesn't come back up. I can hear the motor working Quote
glanzadude Posted May 13, 2016 Posted May 13, 2016 It is a common thing in the ep82 mine is the same also Quote
JamesD89 Posted May 13, 2016 Posted May 13, 2016 Regulators can seize, remove and give it a clean or replace, grease the motor bearings at the same time. Quote
Amjad Posted May 13, 2016 Posted May 13, 2016 Regulator is rusted like crazy! Gonna get another. Not sure if the motor is weak, but it was very slow (even then it needed a few revs) before the movement stopped completely Quote
JamesD89 Posted May 13, 2016 Posted May 13, 2016 (edited) Motor might of just dried out, I greased the bearings when mine was acting up and it ran sweet as a nut for ages after, might be worth a try. What side Amjad? Might have a offside regulator over my lockup, you can have it if so cannot check til Monday though as cars not on the road yet. Edited May 13, 2016 by JamesD89 Quote
Amjad Posted May 13, 2016 Posted May 13, 2016 Ah thanks man, but don't worry because I need one asap. Gonna try get one off ebay, don't really have time to mess about trying to fix mine. Another thing making me think the whole lot is trashed, is that the window actually doesn't even fully close. Like there's some slack and it isn't held shut Does this look correct fitment wise? http://www.ebay.co.uk/itm/Window-regulator-toyota-previa-1993-front-right-85710-20060-ref-kyk37-/221662636555?hash=item339c1f6a0b:g:PocAAOSwzrxUtped Quote
JamesD89 Posted May 13, 2016 Posted May 13, 2016 (edited) That's the one☺ Edited May 13, 2016 by JamesD89 Quote
