fuel venting charcoal canister removed idea
It'll cause vacuum in your tank if blocked off. If it's blocked off and you don't get a hissing/sucking noise when you undo your fuel cap then your fuel system isn't sealed. If you do get a hissing/sucking noise when you undo your fuel cap then your tank is vacuuming. Basically your fuel pump is sucking the fuel out the tank and air is supposed to replace that space but if air can't get in then your tank will vacuum and implode.
Edited by lukEp
