Ep82 - ep91 loom conversion ?
you have to compare each pin on the ep82 and 91 ecy pin outs then match the wires from the ep82 plug to the acording pin on any of the 3 plugs on the glanza
this is for the v ecu in the starbo just use different sex plugs and it will turn in 1 suited for you
post-9966-0-05563700-1452346882_thumb.pn
Edited by 5e colin
Handy diagram - Ive done that wire up a few times now. One setup for a Jam ecu I spliced in above the original plugs as the owner wanted to be able to swap between the ecus (for some reason)
handy indeed stu free 300rpm increase for us gtt boys :)
he probly wanted to mess with his setups till he found something that matches ecu readings well ?
is there a different stock rev limit for the ep82 vs the ep91?
i've heard people say 7600 for ep91 in the past....but i've never really checked...as the rev counter seem to indicate the ep91 limits at the same 7200 rpm based on the red markings
Edited by gorganl2000
