Robbiemclough Posted January 8, 2016 Share Posted January 8, 2016 I am wondering of any loom conversion posts about loom connectors as I want to put an ep82 jam ecu into my glanza, can't seem to find anything about exact pin for pin swap overs and no where to buy one as you probably know Quote Link to post Share on other sites
5e colin Posted January 8, 2016 Share Posted January 8, 2016 go to tgt and check out the ecu pinouts Quote Link to post Share on other sites
lukEp Posted January 8, 2016 Share Posted January 8, 2016 Did this year's ago worked well. Quote Link to post Share on other sites
Robbiemclough Posted January 9, 2016 Author Share Posted January 9, 2016 Cheers for the point in the right direction lads! Is there an actual thread on doing it do ya know? Is it pin for pin and just put the two together for sensors and will have one blank due to manual transmission? Quote Link to post Share on other sites
5e colin Posted January 9, 2016 Share Posted January 9, 2016 (edited) you have to compare each pin on the ep82 and 91 ecy pin outs then match the wires from the ep82 plug to the acording pin on any of the 3 plugs on the glanza this is for the v ecu in the starbo just use different sex plugs and it will turn in 1 suited for you Edited January 9, 2016 by 5e colin Quote Link to post Share on other sites
Robbiemclough Posted January 10, 2016 Author Share Posted January 10, 2016 Cheers mate much appreciated and very helpful! just to clear up why does it say two different PIN numbers? Quote Link to post Share on other sites
Robbiemclough Posted January 10, 2016 Author Share Posted January 10, 2016 Silly me I now get it lol Quote Link to post Share on other sites
Robbiemclough Posted January 10, 2016 Author Share Posted January 10, 2016 Thanks again will have to get this done Asap! Quote Link to post Share on other sites
5e colin Posted January 10, 2016 Share Posted January 10, 2016 just for future readers i went from gt to v plugs so on the gt pinout i written down next to them what pin they go to on the v i know the drawing aint the best ha ha best i could do at the time Quote Link to post Share on other sites
Stu Posted January 13, 2016 Share Posted January 13, 2016 Handy diagram - Ive done that wire up a few times now. One setup for a Jam ecu I spliced in above the original plugs as the owner wanted to be able to swap between the ecus (for some reason) Quote Link to post Share on other sites
5e colin Posted January 13, 2016 Share Posted January 13, 2016 handy indeed stu free 300rpm increase for us gtt boys he probly wanted to mess with his setups till he found something that matches ecu readings well ? Quote Link to post Share on other sites
gorganl2000 Posted January 13, 2016 Share Posted January 13, 2016 (edited) handy indeed stu free 300rpm increase for us gtt boys he probly wanted to mess with his setups till he found something that matches ecu readings well ? is there a different stock rev limit for the ep82 vs the ep91? i've heard people say 7600 for ep91 in the past....but i've never really checked...as the rev counter seem to indicate the ep91 limits at the same 7200 rpm based on the red markings Edited January 13, 2016 by gorganl2000 Quote Link to post Share on other sites
5e colin Posted January 13, 2016 Share Posted January 13, 2016 i havent hit the limiter yet as tho with my gtt ecu i did and my needle is at the same spot so yes must be higher Quote Link to post Share on other sites
gorganl2000 Posted January 13, 2016 Share Posted January 13, 2016 not certain why you haven't...but i hit limiter in my ep91...think i need to check the clocks when i do to confirm....maybe over the weekend when/if i drive the car (tropical island, but we do get rain lol) Quote Link to post Share on other sites
5e colin Posted January 13, 2016 Share Posted January 13, 2016 plug in your multimeter and check that way if you have 1 that does it with cal back function Quote Link to post Share on other sites
gorganl2000 Posted January 13, 2016 Share Posted January 13, 2016 i dont own one ...but i know a friend who should have one at hand Quote Link to post Share on other sites
